framing
ws9876
Solar Expert Posts: 453 ✭✭✭
a little off topic but construction anyway...I am doing a 200 sf dormer/addition. It starts as a dormer and continues out over a platform
about 20 ft. It is sited right at the edge of the roof, not in the middle. The 2x6 wall will be a continuation of the wall inside under the last truss
in the roof on that end. There is a 2 ft extension of the roof past the truss and the siding but its just an overhang and not supported from underneath. I did the platform this year. Framing is for next spring. Has anyone done one of this type and have any suggestions for avoiding problems with the framing.??? thanks. I think there are some engineers here on the forum that tend to have construction experience at a pro level...
If you are talking about the over hang of the existing roof on the gable end , I just tear it off remove the rafter or truss
extend the studs up to the new rafter and sheath the wall and reside .A 2’ unsupported hover hang will sag over time .
If you rebuilt the over hang you could add steel angel brackets to hold it up.
If you want to keep a real dormer look , you really need to save the roof in to the second rafter and double it up ‘ then build the outside wall on top.
Your dormer will be smaller but look as it should . I’ve built a 100 dormers like you describe.Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
