Help with Lynx 1000 Distribution
I have a few questions about installation of Lynx 1000 Distribution.
Current Set Up: 550W
Go Power Solar with Charge Controller
100W Go Power Solar with Charge Controller
Portable
2000 Go Power Inverter, 40A DC/DC Charger, Blue Sea 12V Block, Junction Studs, Converter Charger
I have 2 Lynx 1000 Distribution Boxes, using Shunt from Victron B-712
I’ve linked up the 2 Lynx boxes. I have all the items connected with proper fuses POS to POS and Neg to Neg
My question is:
Does it matter about the placement of each item where is it
installed on the Lynx?
From left to right
Lynx #1 -
Slot 1 is Inverter
Slot 2 is Charge Controller
Slot 3 is Charge Controller
Slot 4 is DC/DC Charger
Lynx #2 -
Slot 1 is 12V Fuse block
Slot 2 is Converter Charger
Slot 3 is Junction studs
Slot 4 is Open
Question 2
How does the batteries charge from solar on this diagram below?
