Connecting a wind turbine to a battery bank
RenoirIII
Registered Users Posts: 1 ✭
Hi All,
I'm a bit apprehensive in connecting a wind turbine to my battery bank and would like a second/third/... opinion.
Already there:
Mastervolt Powercharger 12v 40A Battery Charger for shore power charging.
500W solar through a 50 AMP MPPT Solar Charge Controller
It gets it's common from the Mastervolt AC charger.
The positive 12v charging output runs through a 50A breaker.
All this works well.
I now have a 500W 12/24VDC Wind Turbine (https://www.jaycar.com.au/500w-12-24vdc-wind-turbine/p/MG4550).
It has a PWM controller in the head of the unit.
This then runs in a break switch where you can see the wattage generated and there is a switch to put on the break.
I tried this setup directly on a car battery for testing purposed with the output directly going to the battery terminals.
This worked well.
I have a 12v battery bank made up of 4 x 75 Ah SLA batteries.
I also have 2 x 2 75 Ah SLA batteries for winches and truster respectively.
I noticed that the solar +ve is connected to the battery bank before an isolation switch.
My instinct tells me I can't connect the wind +ve there as well because the wind turbine's PWM will think the batteries are fully charged with the solar coming in.
Where can I connect this +ve wind wire?
Already there:
This worked well.
Hi, this sounds like an interesting set up. Did you get it to work satisfactorily?I would be interested in seeing photos/wiring diagram if you are inclined to share.Regards,Dave
