Controller / panel compatibility question
rdm3
Registered Users Posts: 6 ✭✭
I am installing 2 LG360Q1C-A5 panels in paralell... the current controller is a xantrax C40 pwm. Will this controller be compatible?
What is your battery bank voltage?
If your battery bank is 24 volts, then the LG panel specifications are a good/efficient match:
https://www.lg.com/us/business/solar-panels/lg-LG360Q1C-A5- MPP Voltage (Vmpp) = 36.5 Volts
- MPP Current (Impp) = 9.87 Amps
- 40 amps * 36.5 volts = 1,460 Watts from solar array
- 40 amp controller / 9.87 Amps Imp = ~4.1 panels = 4 LG panels maximum in parallel
If you have a 12 volt battery bank, the controller will work fine (PWM--Pulse Width Modulated) but the Vmp~36.5 volts will be too high--And you will only "use" about 1/2 of the solar panel Wattage.
For a 12 volt battery bank, you want Vmp=~17.5 to 18.5 VDC to "match" the 12 volt battery charging voltage.
Thank you Bill! I have ordered a Renogy 60A MPPT... got a great price - problem solved. I will have all the power I need with room to expand. I very much appreciate your wise counsel and research.
