Line side tap...
icarus
Solar Expert Posts: 5,436 ✭✭✭✭
I’m still designing a series of grid tie systems for a remote location. The way much of the metering works, is the meters and main disconnect is on a pole, and then branches go off to serve various buildings. I am pondering doing the tie at the meter base/ main disconnect. At this point I don’t know the size of the service entrance, I am assuming at this point it is either 200 or 200 amp. We are currently contemplating a 20 kw installation, which would require a 100 amp breaker. To avoid the 120% rule, I can do a line side tap, post meter, pre main disconnect. Does anyone have any experience with these, and any tips?
I noticed, a product mentioned on this site called a “connectder” that plugs into the meter base, with it’s own PV breaker, actually pretty cool. https://connectder.com/products/. It seems that this has a limit of 160 amps through this device, which it would seem would make it pretty limited with a 200 amp service and a 100 amp PV breaker.
any advice is welcome...
