Xantrax SW inverter/charger 5548 need help problem
Hello I have a Xantrax SW inverter apparently it does turn on and I do get the yellow light however and stop producing AC and wondering what is the most common problem on these inverters  it has been a very reliable inverter I’ve had no problems with this unit as someone can help me I would appreciate it I’m kind a new at alternative energy system my regards Vincenzo
  • Dave Angelini
    Dave Angelini Solar Expert Posts: 7,127 ✭✭✭✭✭✭
    How long does it make AC before the "yellow" light? Does it work with large loads.
    Try removing DC and repowering. Is battery voltage good, connections good?
    How long have you had this inverter please? It is one of the older ones just after Trace.
    There are people in the US who will repair these but they are repaired from parts from other inverters.
    This model has been out of support from Xantrex, now Schneider for about 19 + years. I am guessing it is a 1997 or so.
    E-mail offgridsolar@sti.net
  • Bobodude
    Bobodude Registered Users Posts: 12 ✭✭
    I had a 4048 that was acting up and it turned out that the transfer relay contacts burnt off.  It’s a clear case relay on the control board.  It is the first thing to go in Trace inverters of that period.
