KID set up
ws9876
Solar Expert Posts: 453 ✭✭✭
The first time you turn on the MS KID controller it has a menu about battery voltage,type etc. It saves automatically.
Later when you turn on the KID (with Battery) you get the regular menus..but it doesnt have that voltage menu again.There is a bunch of stuff about float,bulk etc....
So when you go to a different setup and voltage,how do you get that menu item back??
Setting it back to factory defaults should do it? Tech menu - press and hold left and right according to the manual.Off-grid.
i,ll try it
