Odyssey 680 agm specs
ws9876
Solar Expert Posts: 453 ✭✭✭
THe spec sheet doesnt even mention bulk/absorb /float etc. I cant find it anywhere. where is this info on the Odyssey 680 AGM?
its a small half size battery..
It is only a 16AH battery.
How many amps do you plan to use to recharge it?
It appears to be marketed as an SLI battery.
A typical 16 AH AGM at 70F ...
Bulk until 14.4v
Then Absorb at 14.4v until 0.1 amp
Then Float at 13.4v
