Here's my equipment...what can I do???
eucid
Registered Users Posts: 2 ✭
Hi,
I'm very much a newbie in this and would like some suggestions. He is a list of what equipment I have:
6 x 250w solar panels Vmp 31.17V / Imp 8.03A
SolarRiver SR2K2TLA1 Inverter (Input - Max DC Power 2.3Kw / Max DC volts 550V / Max current 11A, Output - Max AC Power 2.2kW / Max AC Current 11A / Nominal AC Voltage/range 230/180-270)
3 x GEL car batteries 12V 100Ah
I have had them over 4 years and produce about 1400kw per year (I think that's the figure anyway). And power I don't use just get fed back into the grid, I don't get paid for it as I have just installed them myself. So far I have managed to get everything for free, apart from the wooden A frame I have made which cost me £80.
I feel I have two options -
Option 1 - set up some 12v lights in the house or garden and just have them running at night.
Option 2 - get the batteries to feed back into the house overnight to power things on standby (tv, fridge etc).
The first option seems easier but the second seems better. If either of these is possible, what would I need (especially the charge controller - they just confuse me!) and how much would it cost? Or is there something else I can do this them?
Thanks in advance for any help/ideas.
I guess you are in the Netherlands? Your system is relatively small. Many times is it worth the costs (building permits, labor, etc.) to properly "connect" for GT Tied solar power plan. And many utilities/locations may not allow GT solar connections anyway.
Assuming you 1,400 kWH per day, and that nominal cost of power in Netherlands is ~Eu 0.20 per kWH:- 1,400 kWH per year * Eu 0.20 per kWH = $280 per year
You need to look at the cycle life of those batteries (car batteries are not usually deep cycle design) which may be in the 100-500 Cycle range (if you pull them below ~85% State of Charge (all examples/guesses as to how "your batteries" will behave).
For example, if you cycle them below 85% every night, that is ~365 cycles in 1 year... Or you have to replace those batteries once a year (2 year life for "standby" GEL in UPS applications is pretty standard).
So--What would be the cost of replacing your batteries every 1-2 years (>$280 in energy saved)?
And there is the question of your operation with a GT Capable (?) hybrid AC inverter... Since you have had "no issues" in the last 4 years (no knocks from a utility worker asking about your system), I assume that everything is working (if not 100% legal).
What happens when you generate/backfeed energy to your home panel... When solar power is less than your loads, you are slowing down the meter and using your power during the day--Which is saving you actual money.
When the solar power exceeds your local loads, one of three things may happen (and this depends on your utility meter configuration by your utility).- Meter spins "forward" when you consume power (normal operation)
- Meter spins "backwards" when you generator power back to the utility (in decades past, utility meters worked this way) And you actually put money "in the bank" (generate power daytime, consume power at night). If this is your setup, just about perfect.
- Meter does not spin backwards... If your solar power exceeds your loads, the "excess" power is "lost" to you and give "for free" to the utility. Not great, but for a small system like this, your daytime loads may exceed your solar output much of the time--So not much money is "lost" to you.
- Meter spins forwards if you consume or generator excess energy. New meters (at least in the US) are doing this more and more. This is branded as "revenue" guard. Some folks have been known to install their meter "upside down" for a week or two a month. And when the meter turns backwards, it reduces their bill by a lot. With "revenue guard", the meter spins forwards no matter the direction of energy flow. With GT Solar, this means your "donation" of energy to the utility actually shows up on your energy bill as if you consumed this power....
- Meter phones home when GT solar is detected. Some utilities have worked/programmed their computers to find guerilla solar installations. And in the USA, the utility can pull your meter and the local city can red-tag your home. I have not read of this happening to anyway, but is is in our laws.
Hi.
I'm from the UK, and it's an electrical meter. When we produce more power than we use it stops 'spinning'. We don't get any money for sending it back to the grid - a feed in tariff (don't know if it's called something different elsewhere) would cost us £500 to get and would take too many years to recoup.
The main reason for the post was I have acquired these batteries and want to do something with them, and just wondering what, how easy and how cheap I can do something. The batteries were free and could maybe get some more, if they all fail, I'm not too bothered either. So the life of them doesn't concern me (yet anyway, if proves productive etc, that may change).
- 232 Forum & Website
