Schneider config tool
dennysegler
Registered Users Posts: 1 ✭
I am new to the Schneider products & offgrid systems. I've been an electrical contractor for 30+ years & have completed projects ranging from Casinos in Las Vegas to solar fields for First Solar. I am currently working on an offgrid project that is incorporating 2 systems. 1 - a single inverter Conext 5548 w/ MPPT 80-600. 2 - 2 Conext 6848 inverters w/ 2 MPPT 80-600.
I recently purchased the Config tool to install these systems. There was not any instructions or help with the Config tool. Is there anyone there that has a video or a ladder logic set of instructions for this tool?
Denny
Denny
Rereading your post, I see it's a tool to set up the fear, not string configs.Off-grid.
Hi Denny,Our host, Northern Arizona Wind and Sun, Rick sent me a link to the manual.Generally, where you purchase your Schneider hardware is your first level of support.BillNear San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset
Generally one does not need this tool for Offgrid. It is just as easy to use the SCP, a combox, or the new Conext Gateway. The Gateway will allow remote from site configuration/monitoring. The gateway cost will save a truck roll the first time.
You may need to add drivers to get this tool working. It does have a nice monitoring excel program that may help you. below a link for the driver. It might be good to go to the web site and learn how it works. Good Luck!
https://41j5tc3akbrn3uezx5av0jj1bgm-wpengine.netdna-ssl.com/wp-content/uploads/2016/09/conext-config-usb-driver-v-5-3-bn-0002.zip
E-mail offgridsolar@sti.net
- 234 Forum & Website
