Adding panels
Plucka
Registered Users Posts: 130 ✭✭
I have 400 watt of panels by 2 [800 watts] going to their own mppt controllers then to a bms onto two lithium 180 amp/hr 12 volt batteries wired in parallel.May I add a 200 watt panel again with it own mppt controller and to the same bms [has three connections] as the 800 watts are connected to without causing problems
180ah x 2 = 360ah bank @12v = 4320wh, ÷ 1200w pv = ~C/3.5 charge rate (at STC, actual likely lower). Seems to me that should work, but you should check the BMS spec.Off-grid.
