off grid rv 30amp outlet
aspiringpisces
Registered Users Posts: 4 ✭
I want to supply ac for 2 RVs using 1 air conditioner each plus normal rv refrig tv microwave lights. I have 2 xantrex 4048 inverters ,3 xantrex mppt 60-150 charge controllers 8 250ah 6v batteries do I have what I Need or do I need more batteries and how should I wire this setup with additional batteries do I have enough inverter power ,panels
I did answer your question a bit in your first thread... And asked you what your actual energy usage was.
https://forum.solar-electric.com/discussion/354255/one-battery-bank-two-inverters#latest
Take a look at that thread and see if it helps.
This discussion has been closed.
