How to put a battery through a bench test
richardimorse
richardimorse Registered Users Posts: 98 ✭✭
I have two weak 12V Sealed GEL batteries taken from a 48V system and luckily I have available a 24V inverter charger and a 12V car battery charger to put them through an extended re-conditioning and battery test exercise, what is the best approach to attempt to bring them back.
    That is a difficult question to answer... It does depend on what is 'going wrong' and how your battery Mfg suggest to recover them (if they even document a procedure).
    The following would be my suggestion (fairly conservative--should not make things worse--But I am not a battery engineer):
    Discharge them to below 50% state of charge and recharge them to near 100% using C/20 (5%) rate of charge @ 14.2 volts (~25C).
    GEL batteries can have issues if they "gas" -- This can cause "permanent" bubbles in the GEL/Plate interface and further "ruin" your batteries if they are charged at too high of voltage for too long.
    Do this several times and see if the capacity/current capacity is improved or not. If you recover to 80%+ of capacity--That is doing well...
