Air-X and PV charging
gactrx
Solar Expert Posts: 72 ✭✭
Hi, I have a 300AH 24v bank charged by a 2kw panel array.
I am adding an Air-X 400w wind turbine to connect directly to the batteries.
Absorb voltage is 29.4v and float is 27.6v set in the charge controller. I can adjust the Air-X cut-off voltage on the turbine.
Could someone suggest where I should set this value?
Thanks,
Thanks,
Mine is set to absorb V . it sometimes causes my charge controler to drop out of absorb early . So they don't always work well together.
Off grid since 1984. 430w of panel, 300w suresine , 4 gc batteries 12v system, Rogue mpt3024 charge controller , air breeze windmill, Mikita 2400w generator . Added 2@ 100w panel with a midnight brat -
Thanks very much, I'll look at doing this.Thom said:Mine is set to absorb V . it sometimes causes my charge controler to drop out of absorb early . So they don't always work well together.
Cheers,
