Battery based security lighting help
BB.
Super Moderators, Administrators Posts: 33,745 admin
This discussion was created from comments split from: how to design a solar street light?.
Hi
my question is :
If I have a: 100 watts LED
runs 8 hours per nights
3 days back up
12 volts battery
discharge limit of battery is 75%
4 hours sun a day
temperature( min -7' c) and (max +37' c)
can you please help me to calculate , what size battery and panel do I need ?
thank you so much -
Uisraan, welcome to the forum.
I have split your questions into a separate thread to keep things focused on your needs.
Questions:- Are these 12 volt LED lights or 120 VAC (will you be using an AC inverter)?
- 100 Watts of LEDs is a lot--Can you use less power and/or use motion detector based lights to save energy?
- Do you have any 120 VAC utility power available nearby--If you are going to use a lot electricity, utility power is generally cheaper and more reliable
- Is this a short term installation and/or seasonal usage (i.e., summer camp)?
- What is your worst case need... I.e., Winter, stormy weather, 12+ hours of lighting and 5 days of cloudy weather?
- Will there be somebody to monitor the system (recharge battery bank during bad weather/etc.).
PS: I should add, roughly where will the system be installed (hours of sun per day)?
A lot of the LED's sold around here are labeled "100 watt equivalent", but the bulb may draw only 12 or 14 watts. I wonder what the OP really has for a load...
--vtMaps
