Amp Hour Help
Greg_Salyer_13
Registered Users Posts: 11 ✭✭
I have read many posts explaining amp hour as it relates to batteries and I am just getting more confused! My local Sams has 2 different golf cart batteries...
12V....
(4) 6V wired series/parallel
(2) 12V parallel
12V....
- 20 amp hour rate:155
- Minutes at 25 amps:292
- Minutes at 56 amps:110
- Minutes at 75 amps:77
- Volts:12
- 20 amp hour rate:215
- 5 amp hour rate:157
- 6 amp hour rate:156
- Minutes at 25 amps:395
- Minutes at 75 amps:105
- Volts:6
(2) 12V parallel
If you use 4 of the 6-volt batteries at 12 volts, the 20 hr capacity will be 430 ah.
Two of the 12 volt batteries in parallel will be 310 ah at 12 volts.
--vtMaps
What does "20 hr capacity" mean?
It means that you are drawing the amps at a rate that will kill the battery in 20 hours.
Thus, if you have a 430 ah battery bank, you can draw 21.5 amps for 20 hours. Because of Peukert's law, if you draw more amps, the battery has lower capacity.
--vtMaps
- 232 Forum & Website
