--NO WB--
verdigo
Solar Expert Posts: 428 ✭✭
The discussion title (--No WB--) is what I see on my Classic's display. I am assuming my Wizbang Jr has died. Just wondering if anyone has got this message and if it has failed. They are cheap enough so I guess I should order another?
Dennis.
Dennis.
yes, also if you have a bad/poor connection. Happened when I had to do some rewiring in the Epanel, must have pulled on the little purple wire somehow... good to give it a re and re before ordering a new one...
Hi verdigo,
Is the green LED on the WBjr circuit board on the Shunt flashing. If so about how frequently is that LED flashing?
Try turning off the PV into the Classic OFF, then turn OFF the Battery breaker for the Classic. Wait about 30 seconds. Turn the battery breaker back ON, and then, the PV input breaker to ON.
Did this fix the issue?
Check that Aux2 is set for WBjr.
Have you made any recent changes to the system recently?
Check the Violet wire from the WBjr to the WB is intact.
Thanks for the answers. Vic
I will check those things in the morning. Will have to get inside the e-panel to check the light. Didn't think about the aux2 setting. Will check that as well.
- 621 Discussion Forums/Café
