Looking for low power panel
asteroids
Registered Users Posts: 17 ✭
I have a 12V device that consumes about 0.5w. I'm looking for a decent panel to charge up a 12ah battery. I tried Harbor Freight but that didn't work. Suggestions?
A 1/2 watt * 24 hours per day = 12 Watt*Hours per day
Based on 3 hours of sun per day (excluding dead of winter):- 12 WH per day * 1/0.77 panel+controller losses * 1/3 hours of sun per day = 5.2 Watt solar array minimum
Solartech 10 Watt Multicrystalline Solar Module $52
And a small charge controller:
SunGuard 4.5 Amp 12 Volt Solar Charge Controller $30
I would not put a 10 Watt panel on a 12 AH @ 12 volt battery without a charge controller of some sort.
If I was going to size the array based on battery AH Rating:- 14.4 volts charging * 12 AH * 1/0.77 panel eff * 0.05 rate of charge = 11 Watt minimum
- 14.4 volts charging * 12 AH * 1/0.77 panel eff * 0.10 rate of charge = 22 Watt nominal
- 14.4 volts charging * 12 AH * 1/0.77 panel eff * 0.13 rate of charge = 29 Watts "cost effective" maximum
If the battery is "hot" (95 to 110F or so), it will have higher capacity and higher self discharge (tend towards a bit larger solar panel).
So that gives you a few numbers around which you can pick your solar panel and charge controller.
Of course, I am sure you can find lots of less expensive panels and small charge controllers on Ebay and possibly Craig's List.
Typo I'm sure, but might cause confusion.[*]12 WH per day * 1/0.77 panel+controller losses * 1/3 hours of sun per day = 5.2 volt solar array minimum
Peace
Wow... Where did that come from????
Thank you Wayne.
