Don't ignore the little things
Cariboocoot
Banned Posts: 17,615 ✭✭✭
In case people haven't got the message ...
I just measured someone's "entertainment center" TV, PVR, disc player, and VCR all on one power strip.
With everything "turned off" it was pulling 47 Watts.
47 Watts * 24 hours = 1128 Watt hours: as much as a full-size refrigerator.
The difference is that the refrigerator would be keeping your food cold while the "off" entertainment center is doing nothing.
Re: Don't ignore the little things
I guarantee 30-35 of those watts is just from the DVR, based on my past measurements. There are things that could be done in hardware and software to lower the average DVR load, and I was happy to see the latest one I received (a Genie for Directv) goes into a low-power mode. Haven't done any tests to see what it uses, though.
Really you can't say all of those watts are doing nothing, since the DVR is recording shows at least some of the time.4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is -
My Sat TV receiver sucks back 10 watts 24/7, as much as my freezer converted to fridge. But I have to leave on, otherwise it looses programming and I have to call the company to send it "another hit" to activate it again. That's a criminal design
Re: Don't ignore the little thingsI guarantee 30-35 of those watts is just from the DVR, based on my past measurements. There are things that could be done in hardware and software to lower the average DVR load, and I was happy to see the latest one I received (a Genie for Directv) goes into a low-power mode. Haven't done any tests to see what it uses, though.
Nope: not recording anything. Just sitting there.
But the PVR is the TV link and if you shut it down it "forgets" everything and takes awhile to reboot, and then settings have to be reloaded. No doubt it is the major power eater and yes it needn't be but it's the same old story: the makers of these things see no reason why they can't be chewing up Watts 24/7; it's not their electric bill, so why make it efficient? -
Did a quick test on our Sat Internet for power use and 'just sitting' there it pulls 20 to 21 W constant. 24 x 21 = 504Whrs. So I have been powering down when not in use, then it is only the inverters 18A @ 24V, 432Whrs for a full day cycle.
between the 2 it is just Under 1 Kw if left on...
I have to do a 'look and see' when the little lady is using it to see if it ups its consumption
Re: Don't ignore the little thingsCariboocoot wrote: »Nope: not recording anything. Just sitting there.
Doesn't matter if it is actually recording or not, or "on" or not, as long as it is plugged in most DVRs use the same watts all the time, ready to record whatever is next on the list even if that is 6 hours away. My point is a DVR isn't like a receiver or TV which should draw zero or nearly zero watts when off. The DVR is providing a useful service 24/7.4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is -
Re: Don't ignore the little thingsThe DVR is providing a useful service 24/7.
Ah, you haven't seen the program choices around here. Useful? Not really.
Many are in fact cutting off their TV service because it is such a waste of money. $70 a month is a tad expensive for an hour of news at night. Nothing else worth looking at. Unfortunately no OTA is available in this location. -
BTW I've just tested the PVR on its own and techntrek's numbers are spot-on: 34 Watts whether on or off.
I also tested a receiver-only unit from the same company: 26 Watts while "off".
And to be fair to the whole power strip:
VCR off; 8 Watts
DVD player/recorder off; 2 Watts
40" LCD TV off; 0 Watts (uses <1 Watt to stay ready for remote turn on)
Total is 44 Watts: the 3 Watt difference from the original would be in the realm of variance and unreadable millawatts consumed.
Note that the PVR, VCR, and DVD recorder will all have some power consumption to be in standby mode for remote activation (as the TV or a DVD player only would) as well timer activation. -
Re: Don't ignore the little thingsCariboocoot wrote: »Ah, you haven't seen the program choices around here. Useful? Not really.
Yeah, well, excluding that truism.
If I had hardwire internet I probably would cut mine, too. But, where I live I only have internet via cell phone tether and Directv...4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is -
70 $ for the BASE charge, then if you want to get "specialty" channels, they charge an extra bit - and for every one channel you want, you get 25 that you don't .
When I first started on this adventure - of "going green" - I pulled the plug on my bedside alarm clock - and picked up a battery operated one. It has been about 7 years and counting on that one set of batteries - not using any a/c for that one.... in that time I have seen about 10 people at work say that they are late for work - because the power went out and shut off their alarm clock . . hmmmm. . . ..2 - 255W + 4 - 285W PV - Tristar 60 amp MPPT CC / 3 - 110W PV -wired for 36V- 24V Sunsaver MPPT CC / midnite bat. monitor.
420 Gallon rain water system for laundry.*** 6" Rocket Mass Heater with 10' bed for workshop heat.Current project is drawing up plans for a below grade Hobbit / underground home.Google "undergroundandlovinit" no spaces.
