Watt Meter Wiring
Zakarume
Solar Expert Posts: 143 ✭✭
I have a watt meter and i am trying to wire it in so i can see how many watts coming in and battery volts and so on. I have a source side and a load side. I have a Renogy Charge controller. How do i wire it in to get theses reading?
1460 Watts Solar @24v. 675 AH Battery Bank using 12 6v Trojan T-105. 1 Midnite Classic 150. 1500 Watt 24v Samlex Pure Sine Inverter
Re: Watt Meter Wiring
What brand/model of Watt meter? Do you have a shunt (precision resistor)?
There are a lot of different ones out there.
I have a Renogy Watt Meter. And charge controller. I am only using a small solar power system.
http://www.renogy-store.com/30-amp-charge-controller-p/ctrl-pwm30.htm
http://www.renogy-store.com/product-p/trcrmtr-mt-150.htm1460 Watts Solar @24v. 675 AH Battery Bank using 12 6v Trojan T-105. 1 Midnite Classic 150. 1500 Watt 24v Samlex Pure Sine Inverter -
I could not find any useful specifications--But I would hard pressed to put much more than 20 amps or so through that device (assuming something like 14 AWG to 12 AWG wiring--You may be able to pull upwards of 100 amp peak--very short time frames).
Take a look at the documentation on this site--These meters should work similarly:
http://www.rc-electronics-usa.com/docs/wu100v2_user_manual.pdf
http://www.rc-electronics-usa.com/meter-connections.html
I do not know about the Renogy meter--But the RC meters only read "one direction"--They only add to AH/WH readings, they do not go "up" when charging and go "down" when discharging (as I understand).
I have a couple similar meters.
It's easy enough to use them to measure the amps the charge controller is putting into the batteries, plus voltage. In this case, the "source" is the charge controller, the "load" is the batteries. These meters are connnected to both positive and negative wires.
I put Anderson Powerpoles on my in-line meters to make them easy to move around, I believe I used the 45 amp. I wouldn't run 45 amps through them, though, these meters are meant for low amperage applications. Mine heats up and the screen starts to go dark if there's too many amps going through it.
