How to make a 'perfect' solar absorber
RSSfeed
Registered Users Posts: 3,810 ✭✭
Researchers have developed a solar cell that can tap the sun's full radiation spectrum. The material is a two-dimensional metallic dielectric photonic crystal, and has the additional benefits of absorbing sunlight from a wide range of angles and withstanding extremely high temperatures. Perhaps most importantly, the material can also be made cheaply at large scales.
More...
More...
Re: How to make a 'perfect' solar absorber
Solar ThermoPhotoVoltaic!
An interesting concept. Among the points that may make application of the technology difficult is that the surface has to get hot enough to emit a large amount of light (probably infrared) which is then fed to a PV cell component. Not our backyard panel temperature, I think.SMA SB 3000, old BP panels.
