Samlex Inverter Circuit Board Damage
All Energies
Registered Users Posts: 5 ✭✭
Hi all,
Just cracked open this Samlex inverter to see why the power input light comes on, but no juice comes out.
Owner said it got wet, but I didn't want to believe that a Samlex would be killed by H2O. Now that I'm looking at it, it seems it got very wet. A lot. There looks like there's plenty of water damage all over the board.
While inspecting I came across this component, noticeable because of all the rust-colored excretion around it. I'm wondering if anyone knows what the component is, just for my own education. It looks like a tiny transistor to me...?
Attachment not found.
Looking forward to your thoughts.
-Casey
-Casey
Re: Samlex Inverter Circuit Board Damage
Hi Casey,
That part looks like a Surface-Mount Capacitor. The adjoining part that is not stuffed is labeled C ??, would bet that the white Legend labels the part in question as C-something.
Would bet that the residue is not rust. FWIW. Good Luck, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
Yep, cap. Leaking too.1.8kWp CSUN, 10kWh AGM, Midnite Classic 150, Outback VFX3024E,
