4 X 12v AGM's inverter recommendations
8lander
Registered Users Posts: 18 ✭
I've currently got 2 x 235w-24v panels feeding an outback MPPT 60 to 4 x 12v AGM's in parallel to a 12v 2000 Prowatt inverter. Which I learned this is not ideal.
So if I were to buy a new inverter, what would be best a 24v or a 48v?
Re: 4 X 12v AGM's inverter recommendations
What do you need to run from the inverter?
If the 2kW Prowatt was good enough then going up to a 24 Volt 2kW inverter should be fine: you will improve the current issues without major upgrade expense (going to 48 requires changes in disconnects and over-current protection to accommodate the higher operating Voltage). -
The supply from the 2000w inverter works great for the RV.
So a parallel/series batteries for 24v input would be the better more cost effective way to go.
