pmg inside the nose cone ?
Windy
Registered Users Posts: 18 ✭
Is there any advantage / disadvantage in having the generator inside the nose cone?
Re: pmg inside the nose cone ?
You need to look at bearings, weather/water proofness, ease of service, how heavy the mounts are, any over-speed controls (brakes, feathering, furling, or just short out alternator, etc.). In general, it is a good idea to have at least two methods to slow down/stop a wind turbine.
Also, you usually do not want any electronics in the turbine/nacelle... Everything is up high, subject to weather/ice/vibration, lighting). Having the charge controller/GT inverter on the ground is one less reason you have to go up high to fix something.
If you can find anybody nearby that has flown the same model for 1+ years (and logged power output numbers) you can talk with--That is really helpful. There is a lot that can go wrong as the weather at the top of a tower is very severe.
Thanks alot bro.
I was looking at Aeolos 2kw and looks like its very sealed , look at pictures on google
http://www.youtube.com/watch?v=mEwGgQ3_yQE
