Flexible tubing connection to pump
Bigwooo
Solar Expert Posts: 62 ✭✭
I have a Dankhoff Flowlight booster pump. I wound up making my own flexible connectors for the suction and pressure side of the pump to the rigid water lines. I made it from braided plastic water line and plastic connectors I found at a local plumbing shop. It works, but I'm not happy with it - as it doesn't seem like a very "solid" connection.
Is there a source for professionally pre-made 3/4" ID waterlines for these pumps that anyone has come across? I've searched the internet and can't find anything.
Thanks....
Thanks....
Re: Flexible tubing connection to pump
Any shop that makes up hydraulic or air hoses should be able to make you up something. The suction side should be something that cannot collapse anyway.I have a Dankhoff Flowlight booster pump. I wound up making my own flexible connectors for the suction and pressure side of the pump to the rigid water lines. I made it from braided plastic water line and plastic connectors I found at a local plumbing shop. It works, but I'm not happy with it - as it doesn't seem like a very "solid" connection.
Thanks....
