Question RE: Solar Powered Light
Texas Wellman
Solar Expert Posts: 153 ✭✭
I'm looking to install a light in a remote area for recreational purposes. I'm looking at several models, but for this instance let's just go with a 30 watt LED model that I am looking at.
If I want to use the light 3-4 hours typically or maybe even 5-6 hours (non-typical) about 2-3 days a week what kind of set-up do I need to be looking for?
Do I need a charge controller? I was looking at buying a "12V" panel and a deep-cycle 12V battery and just letting the panel trickle charge the battery. I have good sun in this location. I do not need to use the light every day so if it took 2-3 days to recharge that would probably be OK.
30 watt light /12V = 2.5 amps x 5 hours = 12.5 amp-hours. Considering that a cheap 12V marine-type deep cycle battery has about 100 amp hours I was thinking of coupling it to a smallish (50-100 watts) solar panel to keep it trickle charged. In winter we get about 3-5 hours of sunlight daily here in S. Texas.
Some of the 12V panels I looked at had a rated voltage of 17V. I figured that is probably with no load. If I connected the panel directly to the battery and then had the light come on every night would I over-charge the battery?
I'm not really worried about killing the battery. At approx. $100 and 3-6 months per year use I can replace it yearly if need be.
Thanks for your responses.
Re: Question RE: Solar Powered Light
Why even go thru all that hassle and extra cost?
There are plenty of "all in one" solar lights that you could install for less than $50 that recharge each day and turn on at night. Just look for solar landscaping lights online.Off-Grid in Central Florida since 2005, Full-Time since June 2014 | 12 X Sovello 205w panels, 9 X ToPoint 220w panels, 36x ToPoint 225w panels (12,525 watts total) | Custom built single-axis ground mounts | Complete FP2 Outback System: 3 x FM80, 2 x VFX3648, X240 Transformer, FLEXnet-DC, Mate-3, Hub-10, FW500 AC/DC | 24 x Trojan L16RE-B Batteries 1110ah @ 48v | Honda EU7000is Generator and a pile of "other" Generators | Home-Made PVC solar hot water collector | Custom data logging software http://www.somewhatcrookedcamp.com/monitormate.html -
Thanks for your reply. Most of the landscape lights I have seen are not quite what I am looking for. I have seen some solar powered area flood lights but they seemed kind of dim.
I realize that with 30 watt I'm not getting a lot of light to start with but with LED's it seems like that would go a long ways. I might test the single light out and then add one or two more if it seems to be keeping the battery charged. -
Trickle charging is (roughly) when the current is less than ~1% of the battery capacity (20 hour rate). Any more charging current than that, you should really get a charge controller.
30 watts is a lot more than energy than most of the "inexpensive" LED battery based lamps--So you will probably have to build your own.
For 30 watts at 5 hours per night, you will need roughly:- 30 watts * 5 hours * 1/0.61 DC end to end system eff * 1/3 hours of sun = 500 watt of solar array
- 30 watts * 5 hours * 1/12 volt battery * 2 days of storage * 1/0.50 maximum discharge = 50 AH @ 12 volt battery bank minimum
- 50 AH * 14.5 volts charging * 1/0.77 panel+controller deratings * 0.05 rate of charge = 94 Watt minimum array
To just float a battery over the winter, you could probably use:- 100 AH * 14.5 volts charging * 0.01 float charge rate = 14.5 watt "12 volt" panel for "floating"
9830 Spot Current Draw: 1.4A@12V
There is one specific light I really want to run. The current draw is listed up above. It's rated for 27W. -
TWM Link?
(n#%$*& Not 15 characters)
The link to the lights?
Here http://www.plashlights.com/Driving---Work-Lights.htmlwestbranch wrote: »TWM Link?
(n#%$*& Not 15 characters) -
wow those are tough and BRIGHT! They seem to justify the price... but hard to find much lumens info
Re: Question RE: Solar Powered LightTexas Wellman wrote: »I'm looking to install a light in a remote area for recreational purposes. I'm looking at several models, but for this instance let's just go with a 30 watt LED model that I am looking at.
What type of recreation do you need the light for?
Click on my avatar... then click on my home page.
4W to 100w, I can point you to a Solar Light for any need... -
I have a couple of these (10 watts flood lamps) on order. Them, along with a MorningStar SunLight (SL-10L-12v) controller I Just bought, will keep an outside area of our farm house lit up at night. They may not be much. But, I think they will get the job done.Paul -
Re: Question RE: Solar Powered LightI have a couple of these (10 watts flood lamps) on order. Them, along with a MorningStar SunLight (SL-10L-12v) controller I Just bought, will keep an outside area of our farm house lit up at night. They may not be much. But, I think they will get the job done.
I doubt those meet the advertised 800Lumens, but they get the job done.
What is the AH rating on your battery, ILFE?
I just completed a solar lamp assembly with one of those flood-lights, except this one is built as a motion sensor security light... The assembly has a 1W night-light.
Attachment not found.
I am currently building 7 other assemblies with the same floodlight dusk-to-dawn. -
Re: Question RE: Solar Powered LightI doubt those meet the advertised 800Lumens, but they get the job done.
I agree. That's why I figured I would buy two of them and see how well they illuminate the area in question, prior to buying any more of them.
The battery I have for them at the moment, is 50ah. I have a 100ah battery I can use if I like them well enough and want to expand the system. (I see no need to go to 50% DOD for outside lighting, by going with a smaller battery.)
I also have a spare 100watts panel. So, I will have a completely independent outside lighting system that I just need to look after once per month.Paul
- 232 Forum & Website
