Another battery cable question.
verdigo
Solar Expert Posts: 428 ✭✭
I am mainly just wanting to confirm that I have to make all cables the same length from the battery strings to the bus bar, and from the bus bar to the e-panel/inverter/charge controller. Kinda makes putting this stuff in conduit a pan in the butt.
Dennis
Dennis
Re: Another battery cable question.
Same total length on any paralleled circuit.
So total length of all wires from negative bus bar through a battery string to positive bus bar must be the same on all battery strings.
Positive and negative wires from bus bars to inverter or charge controller do not need to be equal length, they just usually are. -
Thanks again. You guys are great.
