Good package $$ ??
Arkansasoffgrid
Solar Expert Posts: 117 ✭✭
The following is from "SOLAR HOME" page. Does this seem like a good package at $8300.00, comes with roof racks or ground mounts.
The Escape System With MPPT Power Booster ! was designed for a larger cabins with much larger electrical requirements, it includes:
Twelve top of the line big name brand Perlight PLM P-72 280 Watt HIGH EFFICIENCY Poly Crystalline Solar Panels. Comes with a 25 year factory warranty.
One US made Magnum MS4448AE SUPER HEAVY DUTY sine wave DC to AC inverter/charger with a built in 5 stage 125 amp @ 48 volt battery charger so you can charge your batteries from a generator. Comes with a 5 year factory warranty when installed on this Magnum Mini Panel.
Two leg 30 amp AC transfer switch.
One US made Magnum ME-RC50 Remote control panel.
A US made Magnum MBP-MMP Magnum Mini Panel Backplate.
One 175 Amp DC inverter breaker.
One 30 Amp AC input breaker dual pole or 60A single pole.
One 500A/50mv DC shunt.
One DC buss bars for battery positive and negative.
One Din rail or back mount for optional DC mini breakers will hold up to eight breakers.
One Inverter hood
A US made Magnum Mini Panel Enclosure.
1 US made Orion Racking mounting rail sets.
2 US made Orion Racking clamp sets.
1 Outback FM80 80 Amp Multi Point Power Tracking charge controller.
One US made pair of 5 foot 4/0 inverter cables with ring terminals for direct connection to battery.
A US made Midnite Solar MNPV6 Combiner Box
4 US made UL approved 50 ft pairs of PV cable with MC4 connectors attached. A total of 600 ft. of wire !
12 US made lay in grounding lugs.
4 MNEPV10 DC Photovoltaic breakers.
1 MNEPV63 DC Photovoltaic breakers.
20 foot pare of 6 gauge wire.
Instructions.
This kit was designed for cabins that use AC powered devices.
This Inverter Is For 120/240 Volt Applications
http://www.gridtiesolarkits.com/offgrid-perlight-solar-kits.html
One Inverter hood
Instructions.
8-420AH US Battery L-16s, Midnite Classic 150cc, Whiz Bang Jr, Magnum MS4448PAE inverter/charger, 4590w Canadian Solar panels. Honda EU2000i generator.
Re: Good package $$ ??
At a first glance, looks like a touch more expensive than all the same parts would cost at NAWS. You can do the exact math.
Note that this does not include batteries. -
Tried their website for about 30 minutes but couldn't get the of grid kits to load. Will try again later.8-420AH US Battery L-16s, Midnite Classic 150cc, Whiz Bang Jr, Magnum MS4448PAE inverter/charger, 4590w Canadian Solar panels. Honda EU2000i generator. -
Just to make sure that you are trying the site that NorthGuy mentioned, this is the Wind-Sun site:
http://www.solar-electric.com/
VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum.
- 231 Forum & Website
