Outback Inverter accessories questions
verdigo
Solar Expert Posts: 428 ✭✭
If using Outback inverter(s) does one need a Mate and a Hub to change settings?
Re: Outback Inverter accessories questions
You need a Mate at least, the Hub is for adding a FNDC or charge controllers or multiple Inverters together. -
Thanks. Do you ever get by the Inverter Service Center in Whitehouse?
