Australia Leads With Solar Cooling Standard
Re: Australia Leads With Solar Cooling Standard
FYI, initially this refers to " desiccant-based solar cooling systems", similar in principle to propane powered refrigeration, in that the solar component will provide heat into the refrigeration system to drive it rather than produce electricity to run mechanical A/C.SMA SB 3000, old BP panels.
Australia’s standards body, Standards Australia, has published the world’s first solar cooling standard.
