Plastic sheeting for battery box liner?
verdigo
verdigo Solar Expert Posts: 428 ✭✭
I am building a vented compartment for my batteries inside my shed. I would like to line it with plastic sheeting that is not affected by the battery acid or the fumes. I remember an episode of breaking bad where they needed a container to dispose of a body but can't remember what kind of plastic it was. Anyone??
    Re: Plastic sheeting for battery box liner?
    From this website:
    http://www.coleparmer.com/Chemical-Resistance
    Chemical Selected:
    Sulfuric Acid (10-75%)
    Material
    Compatibility
    ABS plastic
    B-Good
    Acetal (Delrin®)
    D-Severe Effect
    Aluminum
    D-Severe Effect
    Brass
    N/A
    Bronze
    B-Good
    Buna N (Nitrile)
    B1-Good
    Carbon graphite
    A1-Excellent
    Carbon Steel
    D-Severe Effect
    Carpenter 20
    A2-Excellent
    Cast iron
    D-Severe Effect
    Ceramic Al203
    A-Excellent
    Ceramic magnet
    N/A
    ChemRaz (FFKM)
    A-Excellent
    Copper
    N/A
    CPVC
    A-Excellent
    EPDM
    B2-Good
    Epoxy
    A1-Excellent
    Fluorocarbon (FKM)
    A-Excellent
    Hastelloy-C®
    B1-Good
    Hypalon®
    B-Good
    Hytrel®
    N/A
    Kalrez
    A-Excellent
    Kel-F®
    A-Excellent
    LDPE
    A1-Excellent
    Natural rubber
    C-Fair
    Neoprene
    B1-Good
    NORYL®
    A-Excellent
    Nylon
    D-Severe Effect
    Polycarbonate
    B1-Good
    Polyetherether Ketone (PEEK)
    D-Severe Effect
    Polypropylene
    A1-Excellent
    Polyurethane
    D-Severe Effect
    PPS (Ryton®)
    A-Excellent
    PTFE
    A-Excellent
    PVC
    A1-Excellent
    PVDF (Kynar®)
    A-Excellent
    Silicone
    D-Severe Effect
    stainless steel - 304
    D-Severe Effect
    stainless steel - 316
    D-Severe Effect
    Titanium
    D-Severe Effect
    Tygon®
    N/A
    Viton®
    A2-Excellent
    Explanation of Footnotes
    1. Satisfactory to 72°F (22°C)
    2. Satisfactory to 120°F (48°C)
    Ratings -- Chemical Effect
    • A = Excellent.
    • B = Good -- Minor Effect,
      slight corrosion or
      discoloration.
    • C = Fair -- Moderate Effect,
      not recommended for
      continuous use. Softening,
      loss of strength,
      swelling may occur.
    • D = Severe Effect, not recommended for ANY use.
    • N/A = Information not
      available.
  • verdigo
    Polypropylene! Thanks!
  • northerner
    northerner Solar Expert Posts: 492 ✭✭✭✭✭✭
    Polyethylene sheeting, which is very common, is excellent as well. You could use the 6 mil sheeting used as a vapor barrier in houses, which is polyethylene.
  • louielouie
    louielouie Registered Users Posts: 18
    recheck your list. i didn't see "body" anywhere. :)
  • verdigo
    northerner wrote: »
    Thanks. Found an Industrial rubber and gasket place to check out which is close to my welding gas place. will be checking them out on Monday.
  • Skippy
    Skippy Solar Expert Posts: 310 ✭✭
    verdigo wrote: »
    You can use 6 mill. Poly for a box liner ? GREAT ! I just picked up a roll 16 feet wide for vapor barrier - cheap to buy too . Stuff is cheap enough, I can put in 3 layers....
    One more problem down :cool:
    2 - 255W + 4 - 285W PV - Tristar 60 amp MPPT CC / 3 - 110W PV -wired for 36V- 24V Sunsaver MPPT CC / midnite bat. monitor.
    420 Gallon rain water system for laundry.***  6" Rocket Mass Heater with 10' bed for workshop heat.
    Current project is drawing up plans for a below grade Hobbit / underground home.
    Google "undergroundandlovinit" no spaces.
  • solarix
    Best thing I've found is Pond Liner. A local community replaced the liner on their golf course pond and we scored a trailer load of the old stuff. 30 mil - tough but not too stiff where it can still be folded in the corners of a battery box so as to have no seams. Don't know where to officially buy it though.
  • Rybren
    Rybren Solar Expert Posts: 351 ✭✭
    HD and Lowes usually carry the liner. Another source is roofing supply places - they'll sell it as EPDM roofing material.
