mi-sol charge control
rich
Solar Expert Posts: 62 ✭✭✭✭
has anybody seen /used /or have any experience with these?Attachment not found...just wondering..
TECHNICAL PARAMETER
RATE CURRENT
60A
NOMINAL VOLTAGE
12VDC
BOOST VOLTAGE
14.5V (25℃), 2h
EQUALIZATION VOLTAGE
14.5V (25℃), 2h
FLOAT VOLTAGE
13.7V (25℃)
LOW VOLTAGE
DISCONNECT FUNCTION
11.4 – 11.9 V Controlled
By the state of charge 11.0V controlled by voltage
Load reconnect voltage
12.8V
Temperature compensation
-4mv/cell*k
DIMENSION
145 x 98 x53 mm (w x h x d)
SELF CONSUMPTION
4 Ma
Ambient temperature range
-40 to + 50℃
Case protection
IP22
TECHNICAL PARAMETER
RATE CURRENT
60A
NOMINAL VOLTAGE
12VDC
BOOST VOLTAGE
14.5V (25℃), 2h
14.5V (25℃), 2h
FLOAT VOLTAGE
13.7V (25℃)
LOW VOLTAGE
DISCONNECT FUNCTION
12.8V
-4mv/cell*k
DIMENSION
SELF CONSUMPTION
4 Ma
-40 to + 50℃
Case protection
IP22
Re: mi-sol charge control
it is another piece of chinese merchandise and it may or may not be good, but imo you will get what you pay for.
