neutral to ground bond in xantrex inverters
mahendra
Solar Expert Posts: 191 ✭✭✭
hi does any know if there is a neutral to ground bond in a xantrex sw 2000. i need to know because, i currently use one through a transfer switch(which i also use a generator through) which has a main breaker . which already has a neutral to ground bond.thanks in advance
Re: neutral to ground bond in xantrex inverters
Yes, there is a neutral to ground bond in the Prowatt SW 2000, the Freedom SW 2000 Inverter/Charger version bonds them when running as a inverter and opens the conection when connected to external power.
http://www.xantrex.com/documents/Inverter-Chargers/Freedom-SW-2000/Freedom%20SW%202000%20InvChg%20Install%20Guide(975-0527-01-01_Rev-C).pdf
