Success at Air-x voltage& Panel Output
Thomas
Solar Expert Posts: 291 ✭
Air-X output from 0 to 18 volts about equivalent to 1 volt per m/p/h., lit the zenon 100w lamp at about 8volts.
Pictures have the output from panels. Ant reason that the shunt/amp from batteries to gti reads power?
though that it does anyway8)
Always troubleshoot with adequate sunlight. Hi Ho Hi Ho
2.3kW [10] Enecsys SMI-240-60 micro inverters
Re: Success at Air-x voltage& Panel Output
I don't know the answer to your question, but I hope you cleared the debris away from the HOT underside of your panels after taking pictures. Cool roof aside, that is a fire waiting to happen.
