Keeping it simple.
Lobo
Registered Users Posts: 18 ✭
Greetings everyone, like all of you we’re at one time I am new to this forum. Having browsed through the forum for a few weeks I haven’t found an answer to a question. I have seen formulas tossed around for this and that, ohms law probably works ... what ever that is, and this old guy just needs some simple recommendations for a charge controller. First, I know what power needs and demands I have. I have five (5) 120 watt 12V (17.6 v from the panels) panels with an optimal output of 6.84 amps each.
I am now looking for a good quality charge controller (not a no-name ebay special that smokes), one that won’t break the bank and prefer a PWM version. Please keep in mind I don’t do formulas (they all look like Chinese hen scratches to me), don’t have a laptop to drag outside to program a CC and wouldn’t understand how to do it anyway, and just want a reliable controller that is plug-n-play (so to speak) that will work. Any suggestions?
Thanks in advance for any suggestions.
Re: Keeping it simple.
Welcome to the forum.
Well you've made it easy: regular 12 Volt panels with an Imp of 6.84. Now, if this is on a 12 Volt system you multiple the Imp by the number of panels (five) and get a maximum current potential of 34.2. So you need a controller that can handle at least that, or 35 Amps and up. You could "choke" it down to 30 Amps if you're on a tight budget.
So,
Morningstar TriStar 45: http://www.solar-electric.com/trts12vochco.html
Morningstar ProStar 30: http://www.solar-electric.com/ps-30.html (I wouldn't pick that one in this case)
Xantrex C40: http://www.solar-electric.com/c40.html
Xantrex C35: http://www.solar-electric.com/tracc35solch.html
If you haven't got a 12 Volt system you'll have a problem with an uneven number of panels. -
Re: Keeping it simple.Cariboocoot wrote: »Welcome to the forum.
So,
Thank you for the response. The intent is to get a 6th panel (matching) and to keep it 12 volt. Can't see any benefit in wiring panels to 24 volt with such a small array (short of wire sizing). Besides, I am confused enough ;-) -
There are good reasons for going to a 24 Volt system: http://forum.solar-electric.com/showthread.php?15989-Battery-System-Voltages-and-equivalent-power
But you can not run a 24 Volt array on a 12 Volt system without an MPPT type charge controller. -
I purchased this from NAWS http://www.solar-electric.com/tr60amp12244.html and it will work at 12, 24, or 48 volts. It will also handle up to 60 amps too. Works well for me and it will function as a LVD (Low Voltage Disconnect) if I choose to use in that capacity in the future if I decide to get an MPPT controller instead of it. They are about $200 and don't forget to get the temp sensor. You can save about $50 if you get the 45 amp version. I always tell them I am buying because they have the forum and I vote with my wallet!12K asst panels charging through Midnite Classic 150's, powering Exeltechs and Outback VFX-3648 inverter at 12 and 48 volts. 2080 AH @ 48 VDC of Panasonic Stationary batteries (2 strings of 1040 AH each) purchased for slightly over scrap, installed August 2013. Outback PSX-240X for 220 volt duties. No genny usage since 2014.
