on-grid panels array connection
egywatt
Registered Users Posts: 2
dears i need your help
i have a small project , all i have is 12 panels of 250W each and an on-grid inverter aurora 3.6KW . i need to know how can i arrange the wiring from each panels to the other ( is it gonna be parallel or in series ) please advice what to do then
thank you in advance nice ppl
abdalla mahmoud
Egywatt
abdalla mahmoud
Egywatt
Re: on-grid panels array connection
We are going to need the specifications for the inverter and for the panels. The inverter should have come with an install manual which would give important information as to the minimum and maximum input Voltages. Many manufacturer's have on-line string size calculators for determining exactly what you need to know.
All we know at this point is that you are about 600 Watts short of maximizing the inverter's output ability.
