a/c DC question
erne
Solar Expert Posts: 41 ✭
I have been installing a solar repeater site for an EMS system and my helper is the assistant chief of said firm. He is an X-navy nuclear electrical technician. During the installation progress he informed me that he also taught new technicians. One of the questions he asked these new students was if they knew how to tell if the problem could be diagnosed by the magic smoke from the circuit board or wire, whether it was on the “a/c” or “DC” side. This was a new diagnostic tool that I had never heard of, and I have been in this industry for many years. I thought maybe I should pass this tip by those of you that are wiser than I. He climes that DC smoke rises in a straight line, while a/c smoke is wavy because of the cycles it runs on. Can any of you verify this as a viable diagnostic tool.
Re: a/c DC question
erne,
where the smoke comes from can give a rough indication of where the problem is sometimes just as burn marks on parts and pc boards could. as to straight and wavy smoke for dc and ac respectively, he is pulling your leg.:p -
Re: a/c DC question
a/c usually is short for air conditioner. I have never seen smoke rise from an a/c.
Niel is quite correct about ac and dc smoke. --vtMaps4 X 235watt Samsung, Midnite ePanel, Outback VFX3524 FM60 & mate, 4 Interstate L16, trimetric, Honda eu2000i -
Re: a/c DC question
Smoke has absolutely NO magical potencies, but, smoke is what drives all things electrical.
Don't believe it? Have you ever seen anything run after the smoke escapes??3500w solar, 800AH with Rolls Surrette, Magnum inverter, Midnite charge controller, Kubota 21kW diesel genset...private well...and just recently connected to city power for additional options...nice to have options -
Re: a/c DC question
He will be sending you out for frequency grease next . :0)
Well that's what I would do!
ThomOff grid since 1984. 430w of panel, 300w suresine , 4 gc batteries 12v system, Rogue mpt3024 charge controller , air breeze windmill, Mikita 2400w generator . Added 2@ 100w panel with a midnight brat -
Re: a/c DC questionI have been installing a solar repeater site for an EMS system and my helper is the assistant chief of said firm. He is an X-navy nuclear electrical technician. During the installation progress he informed me that he also taught new technicians. One of the questions he asked these new students was if they knew how to tell if the problem could be diagnosed by the magic smoke from the circuit board or wire, whether it was on the “a/c” or “DC” side. This was a new diagnostic tool that I had never heard of, and I have been in this industry for many years. I thought maybe I should pass this tip by those of you that are wiser than I. He climes that DC smoke rises in a straight line, while a/c smoke is wavy because of the cycles it runs on. Can any of you verify this as a viable diagnostic tool.
Some time you should look up the story of the Windows utility program "nosmoke.com"SMA SB 3000, old BP panels. -
Re: a/c DC question
Or a left handed monkey wrench, or a bucket of propwash...He will be sending you out for frequency grease next . :0)
Re: a/c DC question
I have 2 quarts of frequency grease and bought his smoke return gun. boy I got to him I only had to pay $400 for it. I didn’t know that prop wash could be used in solar. -
Re: a/c DC question
erne,
glad to see you have a sense of humor as the guys are really having a field day with this.
you could go back to the guy and tell him you have a solution to the smoke, be it ac or dc, just by putting a drip loop near it to extinguish it before it appears all the while pointing to him.:p -
Re: a/c DC questionI have 2 quarts of frequency grease and bought his smoke return gun. boy I got to him I only had to pay $400 for it. I didn’t know that prop wash could be used in solar.
Anybody can see that propwash is only used for wind power, not for solar. (OK, if you are building a solar-wind driven turbine maybe....)SMA SB 3000, old BP panels. -
Re: a/c DC question
Tell him a better diagnostic tool is to dunk the circuit boards into a bucket of steam and watch for condensation in the fallopian tubing. -
Re: a/c DC question
I guess technology has changed the jobsite pranks. What ever happened to sending the new guy to fetch the board stretcher. lol -
Re: a/c DC question
I worked in the oil field for a while, and new guy hazing is pretty commonplace in that workplace. Once a new guy on a drilling rig was approached by a crusty old tool pusher, who told him to haul a huge crescent wrench up to the top of the derrick and tighten the large nuts that hold the support struts together. Actually, those nuts are torqued hydraulically to very high numbers when the derrick is assembled and there's no way they could come loose.fix_it_guy wrote: »I guess technology has changed the jobsite pranks. What ever happened to sending the new guy to fetch the board stretcher. lol
The new guy wasn't as green as the TP thought, so when he went to the tool shack to get the wrench, he picked up a couple of spare nuts, which he took with him up to the top of the derrick. He was up there for a while, and when he came back down he told the TP that all the nuts were tight except for these two he found lying around up there, but he couldn't see where they came from. The guys on the rig said they didn't realize that old TP could climb a derrick that fast.
Re: a/c DC question
i like that story ggunn.
