ClimateRight mini heat pumps
techntrek
Solar Expert Posts: 1,372 ✭✭✭
Just found this - about the size of a small window A/C, low power consumption, mounts outside. Not nearly the same great BTU per watt ratio as the best mini-splits, but still might be an option for some so thought I would pass this along.
http://www.climaterightair.com/cr-2550
http://www.climaterightair.com/cr-7000
Re: ClimateRight mini heat pumps
It looks like a window unit with ducting on it,, sort of the inverse of an indoor portable. My guess is that on a per BTU basis, a good window unit will be more efficient and way cheaper.
2500 BTUs cooling 1800 heating, all while drawing 4.4 amps.
A cheap window unit can be had for under $100, put out 5000 BTUs and start and run on a Honda EU1000 genny.
Not to mention at ~3 BTUs/watt resistance heating, you could get ~2400 BTUs out of a simple electiric heater.
http://www.lowes.com/pd_317014-2251-LRA050XT7_4294859079__?productId=3204001&Ns=p_product_qty_sales_dollar%7C1&pl=1¤tURL=%3FgoToProdList%3Dtrue%26Ns%3Dp_product_qty_sales_dollar%7C1&facetInfo=
Tony -
The specs are a bit better overall for the bigger unit. One advantage of this over a window unit is it only needs 2 three-inch holes instead of one big one.4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is -
I don't know, but call me a skeptic, take a window shaker, put in in a different cabinet, run two pieces of pipe, and curve 4 times as much. I would think carefully.
