Wind Charger / Brake and dump system
Kefalonianman
Solar Expert Posts: 60 ✭✭✭✭
Can anyone let me know if they have experience of the 3 phase 24v charge controller from mississouri wind and sun, thinking of using with two 700w wind energy7 turbines, any experience good or bad appreciated.
Re: Wind Charger / Brake and dump system
Here is one thread that talks about them in general:
Missouri Wind and Solar Turbine, anyone try them?
With any wind turbine setup... Do a lot of research before spending the money. In general, most people don't really have enough sustained wind to make wind worth while. And you should be installing the turbine on a 60 foot minimum tower (at least 30' above obstructions and 500' feet away from taller obstructions).
The wind turbines themselves are usually less than 1/2 the cost of an installed system (tower, wiring, controllers, labor, etc.). The towers are not cheap, plus you may need a crane/lift truck for servicing every year or so.
