Negative bonding block question
tripster
Registered Users Posts: 14 ✭
Hi all. I am new to the forum. Was wondering if there is a less expensive bonding block option for the Xantrex DC250 disconnect than the $79 DCBB that they sell.
Thanks,
Thanks,
Re: Negative bonding block question
Thanks Jim. Right under my nose all this time. Would you know if it is acceptable to use one side of a 60amp double pole breaker to feed the inverter? My Xantrex PS2524 has a 50 amp pass through capability, and specifies a 60 amp max breaker. I can not find a 60A single pole Federal breaker anywhere.
Thanks,
