error in battery bank wiring diagram
vtmaps
I was looking at some Magnum Energy product manuals and I think that there are some errors in their diagrams on how to hook up a series/parallel battery bank.
I have attached one of their diagrams for a 24 volt series parallel bank. I put two red arrows on the diagram pointing to the connections that I believe are wrong.
Am I correct about this, or am I missing something?
--vtMaps
    Re: error in battery bank wiring diagram
    That is a wild diagram....
    It is not wrong in the sense you will blow something up (at least I don't think it is).
    And you are correct if you pull the left red jumper and the right black jumper, then you would have a standard series/parallel connected battery bank.
    However, if you add those two jumper back in (and some people even add two more similar jumpers in the middle of the bank too)--It sort of allows cross string "equalizing" of current/voltage...
    I would not recommend it as the two strings should have almost zero volts difference at each of those jumper points if everything is matched and working well.
    And if you have a problem (say a shorted or open cell, or a poor electrical connection), the additional parallel wiring will just make debugging more difficult and could cause more damage (shorted or open cell, bad wiring, will cause other the interconnected bank to possibly damage its cells from localized over/under charging, etc.).
    At least that is my quick read of the drawing. But, be very careful when following any drawing/wiring practices on lead acid batteries... They can output 1,000's of amperes into a dead short (if the wiring is wrong)--and just ruin your day.
    And add a link to a better diagram of how to "best" connect multiple strings of batteries together:
    www.smartgauge.co.uk/batt_con.html
  • Photowhit
    Well you might not be use to seeing 8 batteries setup in a 24 volt bank, but it appears more than right, but exactly right! assuming the connection made at the battery terminals between the 2 strings is the same wire length/resistance.
    Might like to have fusing at the terminals for the 2 strings.
