Voltage goes up over night ?
Thom
Solar Expert Posts: 196 ✭✭✭
When I go to bed and turn off my invertor I check my dvm. It is most times 12.45 v . In the morning with no wind input it reads 12.6v . I know the batteries read more acurate after resting . Is this the reason a dvm is a poor battery monitor .
Thom
Thom
Off grid since 1984. 430w of panel, 300w suresine , 4 gc batteries 12v system, Rogue mpt3024 charge controller , air breeze windmill, Mikita 2400w generator . Added 2@ 100w panel with a midnight brat
Re: Voltage goes up over night ?
Yes, as the batteries "rest" the electrolyte remixes/diffuses through the battery and stabilizes at the final level (3 hours or so of no charge/discharge).
Also, temperature of the battery bank will affect readings too (probably not in this case--usually takes a while for a battery bank to change temperatures unless somebody is pumping a lot of current through it).
And, it is why measuring voltage is not a very accurate way of estimating state of charge (chemical processes, temperature, specific gravity gradients in battery, etc.).
A Battery Monitor is much better because it measures Amps*Hours (total in and out of the battery). Still not perfect, but much more user friendly.
