Morningstar TS-MPPT-45 Remote Meter 2 (RM-2)
Wanderman
Solar Expert Posts: 180 ✭✭✭
OK...I have all of my panels hooked up and running through the Morningstar MPPT controller.
I have the optional remote meter 2 connected and displaying properly.
Question: How can I determine what the output in watts of my panels is if the batteries are charged. I see a voltage from Solar...but nothing else. What is the best way to figure out what the panels generate??
Thanks,
Rick
Thanks,
Rick
Re: Morningstar TS-MPPT-45 Remote Meter 2 (RM-2)
You either have to put a load on your system (and/or discharge your battery bank to less than 80% state of charge).
Or disconnect the solar panels and:- Put a current meter directly on the panels and measure short circuit current
- Or, connect the panels directly to the battery bank and put a current meter in series to measure the ~Vmp/Imp current to the battery bank (basically, the overcharging the batteries as a load).
Many people, once the battery bank is full (floating), turn on their optional loads (such as water pumping to a tank/garden). This uses otherwise "lost power" and is slightly more efficient (no battery charging/discharging losses).
