Algae in Drain Back Solar Heating System
sunny20kin2010
Registered Users Posts: 5 ✭
I like the drainback hot water system for raidiant floor heat, but how do you stop all the algae from growing ing the storage tank?
Re: Working Thread for Solar Beginner Post/FAQ
Are you sure you have algae growth? I would think that you need some sunlight for the algae to take hold.. You could have bacterial growth--and high temperatures (in the 125-165 F range) should kill much of that (I would guess).
Are you using city water, your own well water, or some other working fluid (like non-toxic antifreeze) for your system?
Re: Algae in Drain Back Solar Heating System
sunny20kin2010,
I also moved your post to its own thread... Easier to follow your questions/answers.
Hi there i have a twin system. The radiant floor heating, storage and gas heating plus wood stove are pressure 1 ATM. the collectors on the roof are a sepperate system having drain back as requird by local code. bove systems are filled by a mixture from deionzed water and a 10% cooling liquid for cars.
I do not have any slug settlements or algae in my system.
Greetings from Greece -
Re: Algae in Drain Back Solar Heating Systemsunny20kin2010 wrote: »I like the drainback hot water system for raidiant floor heat, but how do you stop all the algae from growing ing the storage tank?
Flush the system with #01311 Purging Compound (Pre & Post Operational Cleaner) then add #01205 Molybdate Based Closed System Inhibitor. available from HeatLink group. www.heatlink.com.
NEVER use car antifreeze (ethylene glycol) it is toxic. -
İf it is an open system, is it a once through system? -
Add a few feet of copper plumbing. As the copper slowly leaches out, it posions the growths. also stuff a couple lengths in the septic drains, same thing - helps keep roots out too.
Or some "blue stone" - copper sulphate.
Copper ridge cap, keep moss off roof.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 231 Forum & Website
