Livestock water system
Any suggestions on what type of pump and panels I'd need given this setup and requirements:
A spring fed tank that can supply the pump via gravity.
Lift 25' vertically, and supply approx 1000' of 3/4" poly to a number of tanks with float valves.
move 1000 gallons a day in summer, 700 winter.
Lat 39, Ohio.
Much thanks
Lat 39, Ohio.
Much thanks
Re: Livestock water system
So you need about a 3000gal "supply tank" to store your spring water.
How "clean" is the water - do you need strainers ?
25' lift is not too bad Can you go with 1" pipe? 3/4 is kind of small for a long run
It needs more "head" than most transfer pumps, but less than many well pumps.
figure a 6 hour solar pumping window in summer, 4 hours in winter
Summer : 170 GPH
Winter: : 175 GPH about the same, seasonally, about 3G per minute should do it.
Do you need another tank at the destination end ?
What about cloudy days ?
Will you need battery backup for pumping in winter (now you are talking some real money for enough panels to recharge low batteries in the winter)
What about freeze ups in winter ?
Gosh, no real answers here, just more questions.
The spring in the driest times produces more than 1000 gallons/day. The excess would overflow into a creek. The water is clear.
A second tank at the end of the pump would have to be elevated and would freeze in the winter, not a year round option. The actual stock tanks with float valves would be below grade far enough to only freeze in the most extreme expected temps.
The cloudy days question is one I also have, would the system need to be size accordingly?
1" pipe is possible, a little more costly.
thanks for the help. -
Re: Livestock water systemThe actual stock tanks with float valves would be below grade far enough to only freeze in the most extreme expected temps.
Will the water pipe be exposed to freezing ? and what happens to your float valves if they freeze ?
Will the source pump be damaged if line is stopped with ice plug ?
If you had a 1000 gal tank at the far end of the system, would it freeze solid, or just edges? You likely shouldn't try to refill stock tanks from the pressurized pipe, but use a tank near there. That would also hold you on a cloudy day or 3
All the lines would be buried. The tanks and valves would be about a foot below grade so they wouldn't freeze most winters.
Maybe I should simplify the question. What pump and panel configuration would be used if I had the the tank at the spring, a 25' lift and a storage tank 1000' of pipe away?
- 231 Forum & Website
