User Survey for Solar Lighting System
Hi all,
I am an electrical engineering major doing a design project related to solar power. My group is designing a solar powered system right now, and we would appreciate feedback that any of you may have by completing our survey located at the link below.
http://www.zoomerang.com/Survey/?p=WEB228HLVBGRCH
Thank you very much for your time and consideration!
Re: User Survey for Solar Lighting System
Well, I'll get you off to a good start, I'll read all 3 messages, and take all 3 surveys .
Maybe JMT209 or a moderator can delete the 2 extra ones, or are they all 3 different somehow?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
