Results 1 to 5 of 5
Thread: 12V cabin lighting.
  1. #1
    BillB Guest
    Default 12V cabin lighting.
    I'm trying to set up a small 12V lighting system in an off-grid cabin. I want to have 3 or 4 LCD ceiling lights that will be used only 3 or 4 hours a day, 3 days a week during the summer. What I need to know is what wiring I use and if there is any other equipment I'll need (e.g. Low Voltage Disconnect?). Do I just connect the wiring from battery to the can normally? Thanks, Bill
    Clarification: I'm going to solar charge the battery by itself (not enough sun near the cabin). I just need to know what goes between the battery and the LED lights.
  2. #2
    Default Re: 12V cabin lighting.
    Voltage drop is a real issue with this sort of thing so ...
    http://forum.solar-electric.com/showthread.php?t=29
    (Voltage drop calculator.)
    I think you mean LED lights, not LCD.
    Fused circuit connected to the battery is fine. You could come off LVD terminals on a charge controller (if so equipped) but it isn't really necessary.
    1220 Watts of PV, OB MX60, 232 Amp hrs, OB 3524, Honda eu2000.
    Ohm's Law: Amps = Volts / Ohms
    Power Formula: Watts = Volts * Amps
  3. #3
    Join Date
    Sep 2006
    Location
    Willits, CA
    Posts
    5,818
    Keep in mind, 1w of LED @ 12V is 1 amp, so size your wire accordingly.
    Check the manual for your charge controller, but 5-6A should be within the range of many controllers LVD's.
    1 LED fixture per ordinary household light switch is likely OK, but 5 or 6 amps worth, and the DC arc may wear them out early.
  4. #4
    BillB Guest
    I did mean LED. Thanks. Where would I get a charge controller?
  5. #5
    Quote Originally Posted by BillB View Post
    A good starting place would be the forum host, NAWS:
    http://store.solar-electric.com/chco.html
Similar Threads
  1. Cabin Lighting
    By nasty in forum Off Grid Solar & Battery Systems
    Last Post: May 26th, 2012, 14:38 PDT
  2. Need help designing off grid PV system for outdoor lighting & landscape lighting
    By mehrzad in forum Off Grid Solar & Battery Systems
    Last Post: February 6th, 2012, 7:42 PST
  3. The cabin Appliance's list so far to run off a off gid cabin
    By henry1 in forum Off Grid Solar & Battery Systems
    Last Post: October 19th, 2011, 2:19 PDT
  4. cabin security lighting
    By mwwilley in forum Solar Beginners Corner
    Last Post: September 29th, 2011, 7:08 PDT
  5. 12v lighting
    By nasty in forum Solar Beginners Corner
    Last Post: August 25th, 2011, 23:08 PDT
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
