charging 48 volt sys with 6v batterys
lotek
Solar Expert Posts: 65 ✭✭✭✭
Is this even possable, charge several 6 volt batterys, wired parallel, using wind power.
invert it to AC and use some kind of AC charger to charge 48 volt sys. Im guessing a car charger wouldnt do it?
Re: charging 48 volt sys with 6v batterys
Certainly do-able... Question really is--Is it practical.
To charge a battery bank you have the controller and battery bank efficiencies... And you have the boost controller's efficiencies, and the 48 volt battery bank losses too. Chaining possible losses from turbine to AC outlet--using completely made up numbers:- 0.9 turbine controller * 0.8 6v bank * 0.85 48volt converter * 0.8 48v bank * 0.85 AC inverter = 0.42 overall efficiency
That is what the SMA WindyBoy, Outback, and Midnite Solar people are doing... Taking the output from an appropriate turbine and MPPT it (find the Pmax=Imp*Vmp).
Re: charging 48 volt sys with 6v batterysIs this even possable, charge several 6 volt batterys, wired parallel, using wind power.
Why do you even want to do it? You have 6V wind turbine? More efficient way would be to use 6V to 48V DC-DC converter modified for battery charging. Or use a whole bunch of battery switches to reconfigure eight 6V batteries from parallel to series. Or try to re-wind your wind generator for 48V operation.
- 626 Discussion Forums/Café
