Powerpack 1500
I picked up a Xantrex powerpack 1500 - on wheels.
I want to use it while I get my PV system running - for lights
It seems light on ah so want to add an external battery.
What size battery can I use? I think it presently has about a 60ah agm battery.
Do I have to use an AGM or can I use a lead acid deep cycle?
thanks!
I know the external battery must be charged separately on its own.
thanks!
Re: Powerpack 1500
Stay with the same chemistry as it's original battery - AGM is the most likely, That's what the charger is set for, but larger batteries will need more time to charge. If you add a solar panel, you will also need a charge controller for the panel too, unless you are clever enough to figure how to use the internal one.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 654 Solar Water Pumping
