Where are the 48 volt brushless units found
t12zh
t12zh Solar Expert Posts: 62 ✭✭✭✭
i want to buy just the unit itself (48Volt).
I want to buy one now.
I am going to build a large Vertical unit.
Where can i find a newer brushless unit.
Greg
  • Solar Guppy
    Re: Where are the 48 volt brushless units found
    same place the good performing low wind units are to be found :roll:
  • Noodles
    Noodles Solar Expert Posts: 30 ✭✭
    You might get a useful response to this and other wind-related questions at:
    www.otherpower.com
    http://www.otherpower.com/otherpower_wind_alternators.html
    Mike
  • crewzer
    Pehaps this Google search string will help:
    http://www.google.com/search?hl=en&q=wind+brushless+generator+48&btnG=Search
    HTH,
    Jim / crewzer
    You also might try salvaging normal automotive/truck brushed alternators for your first testing... The brushes should last 5-10,000 hours pretty easily (as they are slip-rings and not commutators).
    That should be worth several years of operations/experimentations until you get the rest of the system right--before you spend big bucks on a brushless unit.
  • t12zh
    I have a friend that knows i am on this wind power quest and found a man that sold me a air 403 (i think) Should do 12 24 36 or 48.
    So i bought it today for 100.00 with new blades that i needed anyway.
    I am going to see if i can repair it.
    Greg
    I am going to start a new thread on it.
